problem while ripping
  • fla-ts
    • Oct 2014
    • 61
    I have problems while ripping, dbPoweramp frequently jams even when there is only one in use
    • 1914
    Re: problem while ripping
    Damaged CD? Any other software that tries to control the CD drive? What security software is running?
      • 46198
      What is jamming? the mouse stops? or CD Ripper freezes at a certain point? does the CD drive disappear from Windows Explorer?
      • fla-ts
        • Oct 2014
        • 61
        No damaged cd's, dbpoweramp stops and is not responding , i even had to restart the computer to get it fixed. I must say every time I start a cd to rip there is another program that start to play the cd (vlc mediaplayer or something)
        The security program i use won't be the problem , I use it since many years end had never an issue with it
          • 46198
          You should not have any other programs accessing the drive when dBpoweramp is, close the other program.
          • Jailhouse
            • Sep 2016
            • 388
            Turn off Autoplay for CDs. In Windows 10, open Control Panel and click on Hardware and Sound. Click the "Play CDs or other media automatically" link on the far right in the AutoPlay section. In the following page under CDs, choose "Take no action" for Audio CD and Enhanced Audio CD. If you want to play a CD in VLC, insert the disk and open it from within the program.
            • fla-ts
              • Oct 2014
              • 61
              I have deleted vlc mediaplayer from my computer. When I open dbpoweramp twice to rip with two drives it still crashes
                • 46198
                You would have to try a 2nd program, such as Exact Audio Copy, to test weather it is the drive (and system, which affects all programs), or just dBpoweramp.
                • fla-ts
                  • Oct 2014
                  • 61
                  Just managed to do about ten cd's, I was hopefull, I thought problem solved and shit again stopped. It's like the system is counting when to abbort.
