[track_unpad] not interpreted
  • Cooksons
    • Mar 2017
    • 26
    Hello,
    I am a new user to dBpoweramp and am trying to set up the CD Ripper. Specifically, I am trying to set up my naming structure for ripped files. I'm trying to use the [track_unpad] value to omit leading zeros in the track number, but this value is not being interpreted during file naming. Specifically, with the Base Location specified as:
    [IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][]\[album]\[disc]-[track_unpad]-[title]
    the written file format is:
    Album Artist\Album Title\1-[track_unpad]-Title
    Please see the attached screenshot for the same information. Can anyone suggest a fix?
    Thanks!
Name:	Screen Shot 2017-03-09 at 11.16.32 PM.png
    • 1914
    Re: [track_unpad] not interpreted
    Maybe "[tag]track_unpad[]" will help. Just a guess...
    • Cooksons
      • Mar 2017
      • 26
      Thank you for the help!
      Unfortunately,
      [IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][]\[album]\[disc]-[tag]track_unpad[]-[title]
      produces:
      Album Artist\Album Title\1--Title
      i.e. nothing is printed
        Can you try this:
        In CDRipper Options >> Meta Data & ID Tag, un-tick Pad track number to 2 digits (ie 02)
        then use [track] in your Naming string e.g.
        [IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][]\[album]\[disc]-[track]-[title]
        • Cooksons
          • Mar 2017
          • 26
          Can you try this:
          Thanks for your help.
          Even though I un-ticked that option, I still get zero padding. Specifically,
          produces
          Album Artist\Album Title\1-05-Title
          Does [track_unpad] work for anyone else? I've searched but can't find any instances of it giving others problems. FYI, I'm using the current version of dBpoweramp on Win 10 Pro.
            I can confirm the behaviour you are seeing, so this looks like a bug in dBpoweramp Music Converter R16.2.
            Using [track] in the Naming string, regardless of the Pad track number to 2 digits (ie 02) setting, produces a padded track number.
            Using [track_unpad] in the Naming string, produces the string [track_unpad] and not an unpadded track number.
              • 46160
              Bug confirmed
              • Cooksons
                • Mar 2017
                • 26
                Thanks guys. I'm comforted to know that it's not just me.
                Cheers
