Rip to temp and then move to iTunes?
  • fmattis
    • Feb 2016
    Just started using version 16 for macOS. With version 15 I would rip the whole CD to a temporary folder and then use the run external DSP to use the OS mv command to move the entire album to the "Automatically add to iTunes" folder" With version 16 it looks like run external is no longer an option. I have tried setting my cd ripper options to "Rip to temporary folder, move album after ripping" and set the path in the main window to the "Automatically add to iTunes" folder, but when I rip it immediately rips directly to the "Automatically rip to iTunes" folder, which if iTunes is running will try moving the rips before they're complete. Is there another setting I am overlooking. Ideally I would like to rip to Music/Temp and then have the album moved to the iTunes folder after it's done (which I could do with the run external DSP).
    Thanks for your help.
    Francis
    Re: Rip to temp and then move to iTunes?
    CD Ripper >> Green Menu >> CD Ripper Options
    When Ripping: Rip to temporary folder, move album after ripping
      • 1685
      The relevant DSP effect is indeed missing in R16 and will be enabled again in the next update; thanks for reporting.
      Also, you no longer need DSP effects to accomplish this, as Spoon pointed out.
      • fmattis
        • Feb 2016
        Thanks Spoon. I do have this enabled, but the tracks are ripped directly to the path I have specified in the main ripper window (which is currently .../iTunes Media/Automatically Add to iTunes/) and not the temporary path, which I'm assuming is the system default temporary folder.
        Thanks again.
          • 1685
          Indeed ripping to temp folder did not work as intended in dBpoweramp R16 for mac, thanks for reporting all the bugs.
          Here's a new beta version:
          "Run External" DSP is back.
          Ripping to temp folder should also work correctly now.
          • fmattis
            • Feb 2016
            This is great. Rip to temp works perfectly for me now. Thank you.
