CD Ripper best sound quality, lossless Level 5 vs uncompressed
    • 6101
    Re: CD Ripper best sound quality, lossless Level 5 vs uncompressed
    Originally posted by Oggy
    I started on the default 5 and now use 8. A work colleague started on 5 and now uses uncompressed, even though he admits he can hear no difference whatsoever between Uncompressed, level 5 and level 8!
    I guess storage is cheap these days...
    He shouldn't hear any difference (given that all these FLAC files are decoded back to the same lossless audio), unless something is very broken with his server/player!
    • Oggy
      • 702
      Was it Spoon who said he put the Uncompressed setting in for the paranoid?!
        • 1878
        Once we had a secretary who told me, that she doesn't zip compress documents for emails, because they will not look so sharp if you print them later on...
        • Oggy
          • 702
