Problem using 14.4
  • zzdpmjpr
    • Aug 2012
    • 9
    Problem using 14.4
    I have been an occasional user of 14.4 (registered version) since 2010.
    Using it today it won't access meta data saying I need to install Reference. I reinstalled 14.4 but no change. It sounds like a pretty basic problem. Can somebody please help/explain.
    Many thanks
    John
    • 46198
    Re: Problem using 14.4
    Visit here, and see which version you can download:
    Enter your Order reference / receipt number when asked, a download link is then presented.
    Lost your order number? visit: https://secure.dbpoweramp.com/lostorder.aspx
    • zzdpmjpr
      • Aug 2012
      • 9
      Thanks for the response
      I did that yesterday, was offered 14.4 which I downloaded and reinstalled. Still unable to access metadata. There was a message saying I need Reference.
        • 46198
        If you uncheck PerfectMeta, AMG, GD3 and musicbrainz from the meta drop menu (leaving just freedb) then it will work.
        • zzdpmjpr
          • Aug 2012
          • 9
          Thanks that's fixed it. I will upgrade next time I do any non trivial ripping
          Kind regards
