Add Accurate Rip Result to Comment
  • DrForce
    • Jan 2017
    • 13
    Normally I include the Ripper and Ripping Mode in the comment for all my lossless files. For example:
    dBpoweramp Secure Mode
    I was wondering if I could also add the AccurateRip Result tag to the comment info as well. I tried creating an ID tag processing DSP effect with the comment in the additions tab like this:
    dBpoweramp Secure Mode / [AccurateRipResult]
    This didn't work, so I was wondering if it was possible to call other ID tags into the comments and have them update dynamically depending on the value of the AccurateRipResult tag?
    Thank you!
    Re: Add Accurate Rip Result to Comment
    It is not possible.
    • DrForce
      • Jan 2017
      • 13
      As a workaround, I tried mapping AccurateRipResult to Comment in the DSP settings but it did not work in CD ripper. I just get a blank comment field. Is this a known bug?
      Interestingly, when I mapped AccurateRipResult to Comment in the music converter it did work as expected.
      Mac Version R15.8 on macOS Sierra.
        The accuraterip result is written on its own at the end, it is not possible to map.
