HDCD Ripping problem
  • VinylDunc
    • Sep 2016
    • 10
    I have been ripping HDCD's with no trouble until Live's "Secret Samadhi". Audio quality is fine, but tracks are cut short by a minute or two. Without the HDCD DSP it does rip as normal.
    Any suggestions?
    Re: HDCD Ripping problem
    Try ripping the cd without hdcd effect, then convert lossless >> lossless with the effect.
    • VinylDunc
      • Sep 2016
      • 10
      would that capture the HDCD layer from however it is stored on the original disc?
      I mean, captured as a 16 bit file it will be a string of 1's & 0's.... surely it is not going to capture more 1's & 0's than the 16bit file will play, so there would be nothing extra to convert into the 24bit extension?
      *ConfusedByTheScience
        HDCD is encoded into the 16 bits.
