Download on Windows 10 using Edge and IE11 does not work
  • TheAndyMac
    • Aug 2016
    • 13
    Trying to download the latest version (purchased) and, in Edge and IE it does not download - it shows the URL being called for the file and the filesize, but not the filename.
    Using Firefox on another machine (my home server, running Windows Server 2012 R2) the download correctly gets the name.
    Have attached screenshots (anonymised) of the download prompts for both Edge and IE below.
    Re: Download on Windows 10 using Edge and IE11 does not work
    You have the security settings turned up too high, you can reset the security levels to the correct ones, the process of doing the download is very simple, in the HTTP Header we provide the filename.
