Not connecting with accuraterip
  • stevetwigs
    • Jun 2012
    Hi, I am experiencing problems with connecting to accuraterip. I have disabled firewalls and antivirus to get it working but nothing.
    it rips securely but doesnt reference accuraterip.
    I have checked all the relevant boxes in the settings to get it going but nothing.
    Its an old XP laptop that i use for ripping only so have'nt turned it on in a while but working with accuraterip last time.
    I thought I would try updating or reinstalling the whole program, however the order retrival isnt working.
    I have exactly the same issue as https://forum.dbpoweramp.com/showthr...ain-and-again.
    So a bit stuck.
    Any help much appreciated.
    Re: Not connecting with accuraterip
    Answered by email.
    • seazedup
      • Jul 2016
      Hi, just as above, i am unable to make a connection with Accuraterip at the moment though it has worked fine with no problems since i first downloaded it in 2014.
      I have tried a reinstall of the original product with no luck and now i have took the plunge and invested in the latest version. Still no luck.
      Anyway you can help? I'm using a Windows 7 desktop.Thanks.
