Gaps within songs, NOT between them
  • Uncle Meat
    • Nov 2026
    I started using dbpoweramp to re-rip my cd's into FLAC format (they were all previously mp3 using windows media player). I'm about 100 or so in, and so far multiple cd's have ripped with gaps/"suckouts" in the middle of songs. I am NOT talking about gaps BETWEEN songs. I have gaps WITHIN songs ranging from quick blips to a 5-min+ absence in a 9-min song. It is incredibly frustrating to listen to, and re-ripping some of the affected titles has the same result. I tested one of the subject discs on my home player and it played absolutely fine, so it's not the disc. Some discs ripped perfectly, but others are unlistenable. Can this be fixed?
    I am ripping on the Level 5 FLAC setting. I tried increasing it, but that didn't work. For reference, these are being played in my new car, since newer vehicles no longer include cd players. The point being that I don't have the option of changing which player is used for them. And it's not the player causing the problem. Playing from the flash drive on my computer yields the same results.
    Using secure ripping? did AccurateRip verify?
    • Uncle Meat
      • Nov 2026
      I was using Burst ripping. When I tried it on Secure it took too long. I had already had one disc take 4.5 hrs to rip less than half of it.
      • Uncle Meat
        • Nov 2026
        And I did have AccurateRip on. I do not recall the results of it. Most of mine show up as inaccurate, likely because I'm ripping a different version.
          You likely need a new CD drive.
          If have a USB drive, ensure is plugged into a powered hub, or a usb port which can supply enough power for the drive.
          • GBrown
            • Oct 2009
            • 431
            There is something wrong with the disc or the drive if secure is taking that long. Switching to Burst mode means the error correction is ignored and explains the large gaps where the disc data can't be read.
              • 1932
              Is the CD copyprotected​​​​​? Which CD is it?
              • Oggy
                • 704
                Have you got C2 pointers enabled? If so, disable it and try a Secure rip again.
                If you still have issues, then you probably need a new, or different CD drive.
                All the best.
