Secure Extraction Log not being saved when using Multi Encoder
  • umbigobunker
    • Aug 2026
    Hi everyone,
    I'm having trouble getting the Secure Extraction Log to be saved when ripping a CD using Multi Encoder.
    My setup has two encoders running at the same time:
    1. CUE Single File Image
    • Path: F:\Documents\Discogs\
    • File Naming:
    [MAXLENGTH]240,[IFCOMP]Compilations\[album][IFMULTI]\Disc [disc][]\[track] - [title] - [artist][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album][IFMULTI]\Disc [disc][]\[artist][][] - [album]
    This is where I would preferably like the Secure Ripping Log.txt to be saved.
    2. AIFF
    • Path: F:\Music\
    • File Naming:
    [MAXLENGTH]240,[IFCOMP]Compilations\[album]\[IFMULTI][disc] [][track] [title] - [artist][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album]\[IFMULTI][disc] [][track] [title][][]
    For the Secure Extraction Log Filename, I currently have:
    [rippedtopath]\Secure Ripping Log.txt
    However, when I rip a CD, the Secure Extraction Log is not saved in either location. I have checked both the CUE destination and the AIFF destination, but I cannot find the log anywhere.
    Ideally, I would like the log to be saved in the same folder as the CUE Single File Image, for example:
    Documents\Discogs\Artist\Album\Secure Ripping Log.txt
    and for a multidisc album, ideally in the appropriate folder created by the CUE naming scheme.
    Am I misunderstanding how [rippedtopath] works when using Multi Encoder? Does [rippedtopath] refer to the destination of one particular encoder, or is it not supported for the Secure Extraction Log in this situation?
    What would be the correct Log Filename configuration to make the Secure Ripping Log save to the CUE Single File Image destination?
    Thanks in advance for any help!
    Sorry it is not possible to have the log when ripping to Single Image Cue inside multi-encoder.
    If you put the AIFF first, it will get the log file, and a batch file to copy them over at the end of ripping might work.
