dBpowerarm cd rom ripping speed
  • Kml
    • Apr 2016
    My cd rom is ausu Blu ray BW 12D1S-U
    In ripping speed setting( maximum & X40 )only choice, but I want to read with a slow&*65292;for example, X10 can help?
    • 1914
    Re: dBpowerarm cd rom ripping speed
    Hey Kml,
    the drive will reduce the speed itself if it has problems to read the disc. As long as the disc is in the accurate rip database accurate rip will tell you anyway if your ripping has been successful without errors. So there is no need to reduce the ripping speed proactive.
    • Kml
      • Apr 2016
      If the rate of decrease will not improve sound quality, as well as various CD-ROM drive will rip archives different?
        • 1914
        Hey Kml,
        if you rip with a lossless codec (i.e. flac, wav) the sound quality can only be decreased by errorenous ripping. The decrease of the speed is just an attempt of the drive to read the audio data without errors (i.e. scratches or fingerprints on the disc). Once dBpa reports that your ripping was accurate, these data can't be improved - they are bit perfect, no matter how difficult it has been for your drive to read those data.
          • 6189
          Originally posted by Dat Ei
          Hey Kml,
          correct, and furthermore, there have been tests that show in some cases SLOWING the ripping speed down made it *harder* to get a good bitperfect rip. So I agree, leave the speed alone and let the software do its job.
          • Kml
            • Apr 2016
            Will put good quality usb cable, power cord, usb filter can improve sound quality rip?
            • jultsu
              • Mar 2016
              • 58
              These things *might* help you with playing back the audio files. For ripping they are absolutely 100% unnecessary.
                • 1914
                Hey Kml,
                only in the beginning of CD drives the audio signal was an analog one. Very soon the audio signal transfer of CD drives became digital. Since that the D/A conversion is part of the sound card or the sound section of the main board.
                So nowadays ripping means a digital readout of the audio data. It's a bit like reading data from a HDD. I think that will help you to understand, that the quality of an usb cable, power cord or whatever will not influence the sound quality.
                AccurateRip gives you certainty if your ripped audio data are an exact, bit perfect copy of the audio data on the CD, or if any errors occured during the readout. If you achieve an accurate rip, than you can be sure you have the best quality that you can get from that CD (in the respect of an exact, digital audio data copy).
                Cables, power cords and DACs (can) have an influence on sound quality when it comes to the point that you want to listen your music and convert your digital data into analog audio signals. But that's totally a different story...
                • Kml
                  • Apr 2016
                  Thank!!
