Cd of a vinyl transfer mysteriously won't rip
  • centurymantra
    • 9
    I have been using a CD recorder to transfer a bunch of my vinyl and had an odd situation come up. When going to rip a CD containing, specifically, a transfer of an album by German electronic musician Conrad Schnitzler - a 1978 album called Con - it will not rip. Not that it won't make a secure copy...but rather, will not even rip at all or begin to try. An error log immediately pops up when hitting the start button:
    Error ripping to Wave, 'Track 2' to 'C:\Users\BryanK\Desktop\Vinyl\Conrad Schnitzler\Con\02 Conrad Schnitzler - Side 1.wav'
    Error unable to open File 'C:\Users\BryanK\Desktop\Vinyl\Conrad Schnitzler\Con\02 Conrad Schnitzler - Side 1.wav' for writing. [clEncoder::BeginConversion]
    Error ripping to Wave, 'Track 3' to 'C:\Users\BryanK\Desktop\Vinyl\Conrad Schnitzler\Con\03 Conrad Schnitzler - Side 2.wav'
    Error unable to open File 'C:\Users\BryanK\Desktop\Vinyl\Conrad Schnitzler\Con\03 Conrad Schnitzler - Side 2.wav' for writing. [clEncoder::BeginConversion]
    When it happened the first time, I thought there may have simply been an anomalous glitch on the CD-R. I made another copy and the same thing happened.
    This is the ONLY time this has happened, so is isolated to this record only. I can play the tracks off of the CD just fine.
    Any ideas for me? Very weird!
  • jultsu
    • Mar 2016
    • 58
    Re: Cd of a vinyl transfer mysteriously won't rip
    http://superuser.com/questions/61331...der-in-windows
    • jultsu
      • Mar 2016
      • 58
      List of forbidden folder names in windows:
      CON: &*8212; console (input and output)
      AUX: &*8212; an auxiliary device. In CP/M 1 and 2, PIP used PUN: (paper tape punch) and RDR: (paper tape reader) instead of AUX:
      LST: &*8212; list output device, usually the printer
      PRN: &*8212; as LST:, but lines were numbered, tabs expanded and form feeds added every 60 lines
      NUL: &*8212; null device, akin to /dev/null
      EOF: &*8212; input device that produced end-of-file characters, ASCII 0x1A
      INP: &*8212; custom input device, by default the same as EOF:
      OUT: &*8212; custom output device, by default the same as NUL:
      I posted a link to this but need moderator approval. Just to let you know, there is nothing wrong with your system or CD.
      • centurymantra
        • 9
        Excellent! That was the problem. It is too bad that DbPoweramp does not supply an error message telling one to rename files in this situation. This would be a good update for the developer to consider.
        Thanks a bunch!
          • 46198
          Noted
