How to rip CD without pauses between songs?
  • AcB
    • Nov 2025
    • 14
    I've ripped several CDs, such as Pink Floyd's "The Wall" and a few live concert CDs, where the songs should flow seamlessly together, without pauses between tracks.
    In my streaming app, I can enable "Gap Playback" option, and that solves the problem. But then I have to disable it for other albums because this option doesn't always work properly in the streaming app.
    Can I also rip a CD like "The Wall" in dBpoweramp without gaps between tracks? For example, with the DSP action called "Audio CD - Remove Gaps"?
    Or another DSP action?
    Thanks for the help!
    Every ripper will rip live cds without gaps, there is nothing more to do.
    It is the player which would put gaps.
    • simbun
      • Apr 2021
      • 264
      Gapless playback is available if both the control point (streaming app) and renderer (streamer/speaker) support the optional UPnP action setNextTransportURI. The toggle is there to allow the control point to communicate with renderers that don't/incorrectly implement setNextTransportURI.
      Gapless playback just means that there won't be any additional silence between tracks, it doesn't strip the 2 seconds of silence that typically follows each track on an audio cd. If your renderer supports gapless playback (there are no gaps when playing The Wall) then it should always be active in the control point.
        As pointed out, dbpoweramp already rips gapless tracks from CDs as gapless. This is default behavior. All the servers/players I use play back my dbpa rips as gapless if the CD is gapless (e.g., Dark Side of the Moon, Live albums, 2nd side of Abbey Road....)
        • AcB
          • Nov 2025
          • 14
          If dBpoweramp already rips gapless tracks by default, what is the purpose of the DSP action called "Audio CD - Remove Gaps"?
            That is for non gapless (non live) CDs, it is to remove the silence between tracks which is on the disc.
              and I suspect rarely used. I've ripped over 5,000 CDs and never used this DSP.
              • mike-rockford
                • Jan 2026
                do you rip the files as lossless wav, or mp3? because I think the mp3 file-format always has teeny tiny gaps or silence, before & after each track - like there's no way around that
                  If rip with Lame (mp3) the delay is written to the header which can be removed.
                    lossless FLAC. No gaps in rips. That said, I have lots of older live shows that are mp3 files and they play gapless for me. I didn't rip them from CDs however.
