Audio CD not recognized
  • Norbert
    • Feb 2016
    Hello,
    I am new to dBpoweramp, just moved from iTunes!
    At the first start I have a Basic Problem: dBpoweramp does not recognize the Audio cd in the drive. The drive is recognized as drive E:. A small Windows opens to reread the drive.
    I can run the Audio cd by Windows Media Player.
    My system:
    - Windows 10 Home 1511 / 10586.104
    - External USB DVD-ROM Teac PU-DVR10-93
    I hope you can help me! :-)
    Thank you in advance!
    Norbert
    • 46160
    Re: Audio CD not recognized
    If you run CD Ripper, it just says 'Insert Disc into Drive E:' ?
    • Norbert
      • Feb 2016
      Yes, exactly:
      And I can retry as often I want, the Windows will be opend every time.
      The Audio cd which is in the DVD-Rom device can be played by the Windows Media Player.
      -Norbert-
        • 46160
        Try starting CD ripper by right click on icon >> Run as Administrator
        • Norbert
          • Feb 2016
          After:
          - running as admin
          - deinstall / install
          - cleaning System from iTunes
          - resetting auto start for media
          And a lot of thinking, I found resolved the issue:
          Eset Smart Security / Media Control: The was an entry for DVD-ROM of read only, after disabling, everything went fine!
          Thank you for your support!
          And greetings from a happy dBpoweramp user :-)
          -Norbert-
