Drive with calculated offset different than database
  • jg7
    • Oct 2025
    Hi, I'm trying to setup accurate rip for my drive that's currently in the database.
    LG Electronics - DVD-RAM GH24NS95 +667 1 100%
    I've found 3 key disc now that return this error:
    AccurateRip will not key to this offset as it mis-matches the drive database offset. [ Calculated offset value: +16 samples, +64 bytes. ]
    The calculated values are the same for each Key disc so I'm assuming my drive is just a different hardware/firmware combination under the same model number.
    Is there a workaround for this?
  • jg7
    • Oct 2025
    Is there a better place for me to post this question? Or any additional information that would help?
      Proper place but Spoon will need to respond.
        • 46370
        Very strange drive, it appears also as:
        LG Electronics - DVDRAM GH24NS95 +6 1079
        without the dash. Has anything happened with this drive, such as flashed with non-standard firmware?
        • jg7
          • Oct 2025
          Ah mine is the one without the dash in device manager.
          I updated the firmware to the current version RN01 and have the same issue.
            • 46370
            I have never seen an LG drive with +16 offset.
