Right Click Properties
  • mrcd
    • Feb 2012
    • 253
    My right click properties do not look the same as they did a week ago. I recall them looking different and having some interaction with the tracks properties that I no longer do. Any ideas what happened?
    • 46198
    You are missing the dBpoweramp shell items, there should be Edit ID Tag and Audio Details.
    Run dBpoweramp Control Center >> Advanced Settings >>
    Uncheck the two first options >> click OK, then go back in and re check them.
