Discs with silent tracks wont load
  • Ian Berrington
    • Jun 2024
    • 115
    Greetings to all in DB Forums. I have recently run into an odd issue that I don't remember having before and am hoping it is a setting in the new version update that I am missing. Today I got a bunch of "new" discs. Among them were 2 that had a bunch of 4 second silent tracks. The one disc had about 85 and the other about 50. When I put the discs into the drive they would not load, and dB was "not responding" on Mac so I had to force quit. Both discs looked perfect (I didn't know at this time that there were silent tracks)so I tried a few times. Eventually I loaded the last version of dB from a Time Machine back up, put the disc in and it loaded right away and displayed all the silent tracks, so I was able to deselect them and rip the discs. Can anybody please tell me what I am missing / doing wrong in the new version?
    Thank you in advance.
  • simbun
    • Apr 2021
    • 264
    I can't offer any advice with your problem (sounds like a bug), but if you deselect the silent tracks from CD Ripper your rip won't be verified with AccurateRip, so delete/hide them after ripping.
    • Ian Berrington
      • Jun 2024
      • 115
      Mmmmm, that is strange, because I got a 100% accurate result after deselecting the silent tracks. On the one disc, with the most silent tracks I did rip them and delete afterwards, the second one I deselected the silent tracks before ripping, and got 100% accurate on all that I ripped. I have also noticed in the past when ripping a disc that, say for example 9 out of 10 tracks ripped accurate and the 10th secure, if I eject the disc, clean it and then rip only the track that was secure the first time, often I get accurate just ripping the one track.
      On the bug, do you think that would be on my end or a bug in the new dB version?
      Thanks for the reply!
      • simbun
        • Apr 2021
        • 264
        I've just tried and you're absolutely right. I might be thinking of an earlier version - or a different software entirely!
        I have to assume it's a problem with the new version if it can't, from a default install, cope with short tracks (I wouldn't have thought it's anything to do with the fact they're silent).
        • Ian Berrington
          • Jun 2024
          • 115
          Good to know it's not me getting old!
            • 1685
            Thanks for the bug report.
            What is the full version number of the old version that works?
            Is there anything else special about these discs? I made a few test disc images with many silent tracks and all appear to load fine.
            Does disabling dBpoweramp internet access help? In case the lockup is related to internet queries.
            • Ian Berrington
              • Jun 2024
              • 115
              Hello Peter, The version that works for me is "Release 2024-11-01 (2)" . The version that is getting stuck and not loading is "Release 2025-05-04 (2)". The discs I think are normal, nothing special. One was "The Stone Roses, Second Coming" and the other was "Sister 7, This Is The Trip", they may be South African pressings but I will look closer tomorrow. The Stone Roses had 12 songs plus another on track 90 and went up to about Track 100, all the tracks from 13 to 100 (except #90) were 4 second silence tracks. On Sister 7 tracks 1 through 11 were songs and another on track 57 the rest also being 4 second silence tracks. It's late here now, but tomorrow I will try again on the new version with internet disabled and let you know how that goes.
              Thank you for the reply,
              Cheers!
              • Ian Berrington
                • Jun 2024
                • 115
                Hi Peter, I double checked the Stone Roses disc this morning with internet disabled, and it is the same, the disc won't load and I have to force quit dB to exit the program. I also checked the disc itself and it is a UK pressing.
                I hope this helps!
                Regards
                  Can you rip that disc in the old version with full secure logging enabled, we are after the full table of contents of the disc from the log which would help diagnose it with a later version.
                  • Ian Berrington
                    • Jun 2024
                    • 115
                    Here you go Spoon, I hope it's what you are looking for:
                    dBpoweramp RRelease 2024-11-01 Digital Audio Extraction Log from 2025-07-17 11:46:31
                    OS version: macOS Version 12.7.6 (Build 21H1320)
                    Drive & Settings
                    Ripping with drive 'disk2 [Apple - SuperDrive]', Drive offset: 0, Overread Lead-in/out: No
                    Ultra:: Vary Drive Speed: No, Min Passes: 2, Max Passes: 2, Finish After Clean Passes: 1
                    Encoder: FLAC -compression-level-5
                    Table of Contents (TOC)
                    Track | Start | Length | Start LBA | End LBA
                    1 | 0:02:00 | 11:21:36 | 0 | 51111
                    2 | 11:23:37 | 5:09:54 | 51112 | 74341
                    3 | 16:33:17 | 4:29:64 | 74342 | 94581
                    4 | 21:03:07 | 6:33:47 | 94582 | 124104
                    5 | 27:36:55 | 2:59:06 | 124105 | 137536
                    6 | 30:35:62 | 3:15:22 | 137537 | 152184
                    7 | 33:51:10 | 4:56:19 | 152185 | 174404
                    8 | 38:47:30 | 4:26:74 | 174405 | 194429
                    9 | 43:14:30 | 5:40:06 | 194430 | 219936
                    10 | 48:54:37 | 6:50:29 | 219937 | 250716
                    11 | 55:44:67 | 4:59:27 | 250717 | 273169
                    12 | 60:44:20 | 5:46:61 | 273170 | 299181
                    13 | 66:31:07 | 0:03:74 | 299182 | 299481
                    14 | 66:35:07 | 0:03:74 | 299482 | 299781
                    15 | 66:39:07 | 0:03:74 | 299782 | 300081
                    16 | 66:43:07 | 0:03:74 | 300082 | 300381
                    17 | 66:47:07 | 0:03:74 | 300382 | 300681
                    18 | 66:51:07 | 0:03:74 | 300682 | 300981
                    19 | 66:55:07 | 0:03:74 | 300982 | 301281
                    20 | 66:59:07 | 0:03:74 | 301282 | 301581
                    21 | 67:03:07 | 0:03:74 | 301582 | 301881
                    22 | 67:07:07 | 0:03:74 | 301882 | 302181
                    23 | 67:11:07 | 0:03:74 | 302182 | 302481
                    24 | 67:15:07 | 0:03:74 | 302482 | 302781
                    25 | 67:19:07 | 0:03:74 | 302782 | 303081
                    26 | 67:23:07 | 0:03:74 | 303082 | 303381
                    27 | 67:27:07 | 0:03:74 | 303382 | 303681
                    28 | 67:31:07 | 0:03:74 | 303682 | 303981
                    29 | 67:35:07 | 0:03:74 | 303982 | 304281
                    30 | 67:39:07 | 0:03:74 | 304282 | 304581
                    31 | 67:43:07 | 0:03:74 | 304582 | 304881
                    32 | 67:47:07 | 0:03:74 | 304882 | 305181
                    33 | 67:51:07 | 0:03:74 | 305182 | 305481
                    34 | 67:55:07 | 0:03:74 | 305482 | 305781
                    35 | 67:59:07 | 0:03:74 | 305782 | 306081
                    36 | 68:03:07 | 0:03:74 | 306082 | 306381
                    37 | 68:07:07 | 0:03:74 | 306382 | 306681
                    38 | 68:11:07 | 0:03:74 | 306682 | 306981
                    39 | 68:15:07 | 0:03:74 | 306982 | 307281
                    40 | 68:19:07 | 0:03:74 | 307282 | 307581
                    41 | 68:23:07 | 0:03:74 | 307582 | 307881
                    42 | 68:27:07 | 0:03:74 | 307882 | 308181
                    43 | 68:31:07 | 0:03:74 | 308182 | 308481
                    44 | 68:35:07 | 0:03:74 | 308482 | 308781
                    45 | 68:39:07 | 0:03:74 | 308782 | 309081
                    46 | 68:43:07 | 0:03:74 | 309082 | 309381
                    47 | 68:47:07 | 0:03:74 | 309382 | 309681
                    48 | 68:51:07 | 0:03:74 | 309682 | 309981
                    49 | 68:55:07 | 0:03:74 | 309982 | 310281
                    50 | 68:59:07 | 0:03:74 | 310282 | 310581
                    51 | 69:03:07 | 0:03:74 | 310582 | 310881
                    52 | 69:07:07 | 0:03:74 | 310882 | 311181
                    53 | 69:11:07 | 0:03:74 | 311182 | 311481
                    54 | 69:15:07 | 0:03:74 | 311482 | 311781
                    55 | 69:19:07 | 0:03:74 | 311782 | 312081
                    56 | 69:23:07 | 0:03:74 | 312082 | 312381
                    57 | 69:27:07 | 0:03:74 | 312382 | 312681
                    58 | 69:31:07 | 0:03:74 | 312682 | 312981
                    59 | 69:35:07 | 0:03:74 | 312982 | 313281
                    60 | 69:39:07 | 0:03:74 | 313282 | 313581
                    61 | 69:43:07 | 0:03:74 | 313582 | 313881
                    62 | 69:47:07 | 0:03:74 | 313882 | 314181
                    63 | 69:51:07 | 0:03:74 | 314182 | 314481
                    64 | 69:55:07 | 0:03:74 | 314482 | 314781
                    65 | 69:59:07 | 0:03:74 | 314782 | 315081
                    66 | 70:03:07 | 0:03:74 | 315082 | 315381
                    67 | 70:07:07 | 0:03:74 | 315382 | 315681
                    68 | 70:11:07 | 0:03:74 | 315682 | 315981
                    69 | 70:15:07 | 0:03:74 | 315982 | 316281
                    70 | 70:19:07 | 0:03:74 | 316282 | 316581
                    71 | 70:23:07 | 0:03:74 | 316582 | 316881
                    72 | 70:27:07 | 0:03:74 | 316882 | 317181
                    73 | 70:31:07 | 0:03:74 | 317182 | 317481
                    74 | 70:35:07 | 0:03:74 | 317482 | 317781
                    75 | 70:39:07 | 0:03:74 | 317782 | 318081
                    76 | 70:43:07 | 0:03:74 | 318082 | 318381
                    77 | 70:47:07 | 0:03:74 | 318382 | 318681
                    78 | 70:51:07 | 0:03:74 | 318682 | 318981
                    79 | 70:55:07 | 0:03:74 | 318982 | 319281
                    80 | 70:59:07 | 0:03:74 | 319282 | 319581
                    81 | 71:03:07 | 0:03:74 | 319582 | 319881
                    82 | 71:07:07 | 0:03:74 | 319882 | 320181
                    83 | 71:11:07 | 0:03:74 | 320182 | 320481
                    84 | 71:15:07 | 0:03:74 | 320482 | 320781
                    85 | 71:19:07 | 0:03:74 | 320782 | 321081
                    86 | 71:23:07 | 0:03:74 | 321082 | 321381
                    87 | 71:27:07 | 0:03:74 | 321382 | 321681
                    88 | 71:31:07 | 0:03:74 | 321682 | 321981
                    89 | 71:35:07 | 0:03:74 | 321982 | 322281
                    90 | 71:39:07 | 6:25:74 | 322282 | 351231
                    91 | 78:05:07 | 0:03:74 | 351232 | 351531
                    92 | 78:09:07 | 0:03:74 | 351532 | 351831
                    93 | 78:13:07 | 0:03:74 | 351832 | 352131
                    94 | 78:17:07 | 0:03:74 | 352132 | 352431
                    95 | 78:21:07 | 0:03:74 | 352432 | 352731
                    96 | 78:25:07 | 0:03:74 | 352732 | 353031
                    97 | 78:29:07 | 0:03:74 | 353032 | 353331
                    98 | 78:33:07 | 0:03:74 | 353332 | 353631
                    99 | 78:37:07 | 0:03:74 | 353632 | 353931
                    Extraction Log
                    Track 1: Ripped LBA 0 to 51112 (11:21) in 1:01. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/01 Stone Roses, The - Breaking into Heaven.flac
                    AccurateRip: Accurate (confidence 133) [Pass 1]
                    CRC32: B7DE4FCB AccurateRip CRC: F5FFDA79 [DiscID: 099-01c2473e-600c220a-fe126f63-1]
                    AccurateRip Verified Confidence 133 [CRCv2 f5ffda79], Using Pressing Offset +6
                    AccurateRip Verified Confidence 2 [CRCv1 8b1f08a9], Using Pressing Offset +1342
                    Track 2: Ripped LBA 51112 to 74342 (5:09) in 0:21. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/02 Stone Roses, The - Driving South.flac
                    AccurateRip: Accurate (confidence 137) [Pass 1]
                    CRC32: BF73C18F AccurateRip CRC: 1548D4D0 [DiscID: 099-01c2473e-600c220a-fe126f63-2]
                    AccurateRip Verified Confidence 137 [CRCv2 1548d4d0], Using Pressing Offset +6
                    AccurateRip Verified Confidence 2 [CRCv1 3bc022da], Using Pressing Offset +1342
                    Track 3: Ripped LBA 74342 to 94582 (4:29) in 0:17. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/03 Stone Roses, The - Ten Storey Love Song.flac
                    AccurateRip: Accurate (confidence 134) [Pass 1]
                    CRC32: 00727922 AccurateRip CRC: EA8BC8A6 [DiscID: 099-01c2473e-600c220a-fe126f63-3]
                    AccurateRip Verified Confidence 134 [CRCv2 ea8bc8a6], Using Pressing Offset +6
                    AccurateRip Verified Confidence 2 [CRCv1 15b5b893], Using Pressing Offset +1342
                    Track 4: Ripped LBA 94582 to 124105 (6:33) in 0:23. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/04 Stone Roses, The - Daybreak.flac
                    CRC32: 57DA3640 AccurateRip CRC: 24B095AC [DiscID: 099-01c2473e-600c220a-fe126f63-4]
                    AccurateRip Verified Confidence 137 [CRCv2 24b095ac], Using Pressing Offset +6
                    AccurateRip Verified Confidence 48 [CRCv2 283c281b], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 b770165], Using Pressing Offset +1342
                    Track 5: Ripped LBA 124105 to 137537 (2:59) in 0:10. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/05 Stone Roses, The - Your Star Will Shine.flac
                    CRC32: 63F00E6A AccurateRip CRC: C7CD2E2B [DiscID: 099-01c2473e-600c220a-fe126f63-5]
                    AccurateRip Verified Confidence 134 [CRCv2 c7cd2e2b], Using Pressing Offset +6
                    AccurateRip Verified Confidence 49 [CRCv2 3e477ab5], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 878968f1], Using Pressing Offset +1342
                    Track 6: Ripped LBA 137537 to 152185 (3:15) in 0:10. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/06 Stone Roses, The - Straight to the Man.flac
                    AccurateRip: Accurate (confidence 135) [Pass 1]
                    CRC32: E2286079 AccurateRip CRC: 2A84C551 [DiscID: 099-01c2473e-600c220a-fe126f63-6]
                    AccurateRip Verified Confidence 135 [CRCv2 2a84c551], Using Pressing Offset +6
                    AccurateRip Verified Confidence 49 [CRCv2 3585636a], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 82f41e8e], Using Pressing Offset +1342
                    Track 7: Ripped LBA 152185 to 174405 (4:56) in 0:15. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/07 Stone Roses, The - Begging You.flac
                    CRC32: 2AF78D24 AccurateRip CRC: 01B4195B [DiscID: 099-01c2473e-600c220a-fe126f63-7]
                    AccurateRip Verified Confidence 137 [CRCv2 1b4195b], Using Pressing Offset +6
                    AccurateRip Verified Confidence 48 [CRCv2 52c04b31], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 da532ab1], Using Pressing Offset +1342
                    Track 8: Ripped LBA 174405 to 194430 (4:27) in 0:13. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/08 Stone Roses, The - Tightrope.flac
                    AccurateRip: Accurate (confidence 136) [Pass 1]
                    CRC32: 40F9188B AccurateRip CRC: CC6E3E69 [DiscID: 099-01c2473e-600c220a-fe126f63-8]
                    AccurateRip Verified Confidence 136 [CRCv2 cc6e3e69], Using Pressing Offset +6
                    AccurateRip Verified Confidence 48 [CRCv2 8087da59], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 6b26964e], Using Pressing Offset +1342
                    Track 9: Ripped LBA 194430 to 219937 (5:40) in 0:16. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/09 Stone Roses, The - Good Times.flac
                    CRC32: 0EAB8B5A AccurateRip CRC: F34647A6 [DiscID: 099-01c2473e-600c220a-fe126f63-9]
                    AccurateRip Verified Confidence 134 [CRCv2 f34647a6], Using Pressing Offset +6
                    AccurateRip Verified Confidence 48 [CRCv2 675415bb], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 eb485981], Using Pressing Offset +1342
                    Track 10: Ripped LBA 219937 to 250717 (6:50) in 0:18. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/10 Stone Roses, The - Tears.flac
                    CRC32: 8ABEB7BB AccurateRip CRC: DCDA5035 [DiscID: 099-01c2473e-600c220a-fe126f63-10]
                    AccurateRip Verified Confidence 134 [CRCv2 dcda5035], Using Pressing Offset +6
                    AccurateRip Verified Confidence 46 [CRCv2 fc259829], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 38cb3d7c], Using Pressing Offset +1342
                    Track 11: Ripped LBA 250717 to 273170 (4:59) in 0:13. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/11 Stone Roses, The - How Do You Sleep.flac
                    CRC32: 279EEBB9 AccurateRip CRC: AD979E09 [DiscID: 099-01c2473e-600c220a-fe126f63-11]
                    AccurateRip Verified Confidence 135 [CRCv2 ad979e09], Using Pressing Offset +6
                    AccurateRip Verified Confidence 49 [CRCv2 56c8d85d], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 fae2a5b7], Using Pressing Offset +1342
                    Track 12: Ripped LBA 273170 to 299182 (5:46) in 0:14. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/12 Stone Roses, The - Love Spreads.flac
                    CRC32: AE763CBA AccurateRip CRC: 1E38D65B [DiscID: 099-01c2473e-600c220a-fe126f63-12]
                    AccurateRip Verified Confidence 135 [CRCv2 1e38d65b], Using Pressing Offset +6
                    AccurateRip Verified Confidence 45 [CRCv2 8f839a2b], Using Pressing Offset +1354
                    AccurateRip Verified Confidence 2 [CRCv1 1e9c039b], Using Pressing Offset +1342
                    Track 13: Ripped LBA 299182 to 299482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/13 Stone Roses, The - [Silence].flac
                    Secure [Pass 1 & 2, Ultra 1 to 2]
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-13]
                    Track 14: Ripped LBA 299482 to 299782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/14 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-14]
                    Track 15: Ripped LBA 299782 to 300082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/15 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-15]
                    Track 16: Ripped LBA 300082 to 300382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/16 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-16]
                    Track 17: Ripped LBA 300382 to 300682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/17 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-17]
                    Track 18: Ripped LBA 300682 to 300982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/18 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-18]
                    Track 19: Ripped LBA 300982 to 301282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/19 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-19]
                    Track 20: Ripped LBA 301282 to 301582 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/20 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-20]
                    Track 21: Ripped LBA 301582 to 301882 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/21 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-21]
                    Track 22: Ripped LBA 301882 to 302182 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/22 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-22]
                    Track 23: Ripped LBA 302182 to 302482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/23 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-23]
                    Track 24: Ripped LBA 302482 to 302782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/24 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-24]
                    Track 25: Ripped LBA 302782 to 303082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/25 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-25]
                    Track 26: Ripped LBA 303082 to 303382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/26 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-26]
                    Track 27: Ripped LBA 303382 to 303682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/27 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-27]
                    Track 28: Ripped LBA 303682 to 303982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/28 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-28]
                    Track 29: Ripped LBA 303982 to 304282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/29 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-29]
                    Track 30: Ripped LBA 304282 to 304582 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/30 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-30]
                    Track 31: Ripped LBA 304582 to 304882 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/31 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-31]
                    Track 32: Ripped LBA 304882 to 305182 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/32 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-32]
                    Track 33: Ripped LBA 305182 to 305482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/33 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-33]
                    Track 34: Ripped LBA 305482 to 305782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/34 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-34]
                    Track 35: Ripped LBA 305782 to 306082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/35 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-35]
                    Track 36: Ripped LBA 306082 to 306382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/36 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-36]
                    Track 37: Ripped LBA 306382 to 306682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/37 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-37]
                    Track 38: Ripped LBA 306682 to 306982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/38 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-38]
                    Track 39: Ripped LBA 306982 to 307282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/39 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-39]
                    Track 40: Ripped LBA 307282 to 307582 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/40 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-40]
                    Track 41: Ripped LBA 307582 to 307882 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/41 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-41]
                    Track 42: Ripped LBA 307882 to 308182 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/42 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-42]
                    Track 43: Ripped LBA 308182 to 308482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/43 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-43]
                    Track 44: Ripped LBA 308482 to 308782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/44 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-44]
                    Track 45: Ripped LBA 308782 to 309082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/45 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-45]
                    Track 46: Ripped LBA 309082 to 309382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/46 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-46]
                    Track 47: Ripped LBA 309382 to 309682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/47 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-47]
                    Track 48: Ripped LBA 309682 to 309982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/48 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-48]
                    Track 49: Ripped LBA 309982 to 310282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/49 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-49]
                    Track 50: Ripped LBA 310282 to 310582 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/50 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-50]
                    Track 51: Ripped LBA 310582 to 310882 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/51 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-51]
                    Track 52: Ripped LBA 310882 to 311182 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/52 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-52]
                    Track 53: Ripped LBA 311182 to 311482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/53 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-53]
                    Track 54: Ripped LBA 311482 to 311782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/54 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-54]
                    Track 55: Ripped LBA 311782 to 312082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/55 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-55]
                    Track 56: Ripped LBA 312082 to 312382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/56 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-56]
                    Track 57: Ripped LBA 312382 to 312682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/57 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-57]
                    Track 58: Ripped LBA 312682 to 312982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/58 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-58]
                    Track 59: Ripped LBA 312982 to 313282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/59 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-59]
                    Track 60: Ripped LBA 313282 to 313582 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/60 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-60]
                    Track 61: Ripped LBA 313582 to 313882 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/61 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-61]
                    Track 62: Ripped LBA 313882 to 314182 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/62 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-62]
                    Track 63: Ripped LBA 314182 to 314482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/63 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-63]
                    Track 64: Ripped LBA 314482 to 314782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/64 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-64]
                    Track 65: Ripped LBA 314782 to 315082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/65 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-65]
                    Track 66: Ripped LBA 315082 to 315382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/66 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-66]
                    Track 67: Ripped LBA 315382 to 315682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/67 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-67]
                    Track 68: Ripped LBA 315682 to 315982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/68 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-68]
                    Track 69: Ripped LBA 315982 to 316282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/69 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-69]
                    Track 70: Ripped LBA 316282 to 316582 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/70 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-70]
                    Track 71: Ripped LBA 316582 to 316882 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/71 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-71]
                    Track 72: Ripped LBA 316882 to 317182 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/72 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-72]
                    Track 73: Ripped LBA 317182 to 317482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/73 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-73]
                    Track 74: Ripped LBA 317482 to 317782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/74 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-74]
                    Track 75: Ripped LBA 317782 to 318082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/75 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-75]
                    Track 76: Ripped LBA 318082 to 318382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/76 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-76]
                    Track 77: Ripped LBA 318382 to 318682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/77 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-77]
                    Track 78: Ripped LBA 318682 to 318982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/78 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-78]
                    Track 79: Ripped LBA 318982 to 319282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/79 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-79]
                    Track 80: Ripped LBA 319282 to 319582 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/80 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-80]
                    Track 81: Ripped LBA 319582 to 319882 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/81 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-81]
                    Track 82: Ripped LBA 319882 to 320182 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/82 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-82]
                    Track 83: Ripped LBA 320182 to 320482 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/83 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-83]
                    Track 84: Ripped LBA 320482 to 320782 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/84 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-84]
                    Track 85: Ripped LBA 320782 to 321082 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/85 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-85]
                    Track 86: Ripped LBA 321082 to 321382 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/86 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-86]
                    Track 87: Ripped LBA 321382 to 321682 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/87 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-87]
                    Track 88: Ripped LBA 321682 to 321982 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/88 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-88]
                    Track 89: Ripped LBA 321982 to 322282 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/89 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-89]
                    Track 90: Ripped LBA 322282 to 351232 (6:26) in 0:15. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/90 Stone Roses, The - The Foz.flac
                    AccurateRip: Accurate (confidence 98) [Pass 1]
                    CRC32: 2AED2B71 AccurateRip CRC: EDB5707F [DiscID: 099-01c2473e-600c220a-fe126f63-90]
                    AccurateRip Verified Confidence 98 [CRCv2 edb5707f], Using Pressing Offset +6
                    AccurateRip Verified Confidence 40 [CRCv2 c439728d], Using Pressing Offset +1354
                    Track 91: Ripped LBA 351232 to 351532 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/91 Stone Roses, The - [Silence].flac
                    AccurateRip: Inaccurate (confidence 22) Secure [Pass 1 & 2, Ultra 1 to 2]
                    CRC32: 1BCACD84 AccurateRip CRC: 66BDDDF1 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-91]
                    Track 92: Ripped LBA 351532 to 351832 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/92 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-92]
                    Track 93: Ripped LBA 351832 to 352132 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/93 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-93]
                    Track 94: Ripped LBA 352132 to 352432 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/94 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-94]
                    Track 95: Ripped LBA 352432 to 352732 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/95 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-95]
                    Track 96: Ripped LBA 352732 to 353032 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/96 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-96]
                    Track 97: Ripped LBA 353032 to 353332 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/97 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-97]
                    Track 98: Ripped LBA 353332 to 353632 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/98 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-98]
                    Track 99: Ripped LBA 353632 to 353932 (0:04) in 0:00. Filename: /Users/ianberrington/Flac/Stone Roses, The/Second Coming/99 Stone Roses, The - [Silence].flac
                    CRC32: 02864C0E AccurateRip CRC: 00000000 (CRCv2) [DiscID: 099-01c2473e-600c220a-fe126f63-99]
                    99 Tracks Ripped: 13 Accurate, 86 Secure
                      • 1685
                      I ordered this album and will test when it arrives.
                      In meanwhile, it would be most helpful if you could test if any of these old beta versions loads the disc:
                      • Ian Berrington
                        • Jun 2024
                        • 115
                        Hi Peter,
                        I can confirm that all of these versions load the disc in seconds.
                        Regards,
                        Ian
                        • Ian Berrington
                          • Jun 2024
                          • 115
                          Peter, It seems that my previous reply is for some reason "unapproved". I confirm that all of these versions load the disc in seconds.
                          Cheers!
                            • 1685
                            Thanks for testing.
                            What if you stay clear of 'manual meta review' page in latest dBpoweramp? If you configured dBpoweramp to automatically show it (ripper menu button / Active Providers / After Metadata Display Review Metadata), uncheck the option.
                            A plausible explanation is that recent changes in that area are going off the rails for you.
                            • Ian Berrington
                              • Jun 2024
                              • 115
                              Thanks for testing.
                              I will try that shortly and let you know.
