Not in accurate rip
  • jfrenil
    • Oct 2021
    Not in accurate rip
    I put in a cd Lionel Richie, Back to front. And CD Ripper says "Not in Accurate Rip". That cannot be true? What could be the reason for this?
    Might that it be that Accurate Rip server is down. Or is my network somehow cut of? Running release 2025-04-17 64bit on Windows 11.
  • jfrenil
    • Oct 2021
Name:	Not in accurate rip.jpg
      • 46221
      Try pressing refresh on the tool bar
      • jfrenil
        • Oct 2021
        Evening greetings from Sweden. :-)
        I did.
        I have now tried the new version on a computer running windows 10 instead (an older desk-top with a DVD built in, no USB-drive).
        Usually CD-ripper wants to adjust the off-set when run on a computer for the first time. Noticed that that step was omitted. Same problem, cd:s previously ripped with accurate-rip now report "not in accurate rip".
        Have also tried defeating Windows Defender and Avira Antivirus real-time protection, but that does not help. Next step is to install an older version of dBPoweramp.
        • jfrenil
          • Oct 2021
          Got back to dBRefMusic-2023-01-20, but that did not fix the issue. I give up - for now. It seems that something in my setup make the network connection in CD-ripper die.
            • 46221
            Try:
            and reset all settings option
            • jfrenil
              • Oct 2021
              Thanks, while you wrote that. I made CDGRAB.EXE an exception from the apps that Avira watch. And voila. Success! Hope it lasts! :-)
Name:	Not in accurate rip2.jpg
                • 46221
                Crappy anti virus, if a computer is not working right it is normally security software.
