Meta Data retrieval problems
  • Altheia
    • 8
    I love CD ripper and have used it for years!
    The last few days retrieving Meta data is not working or working intermittently. I have tried CDs that I have ripped in the past successfully and now the metadata does not appear. It shows that it is in accurip? It shows the Artist but no track titles. If I use I tunes the Metadata shows immediately.
    Any ideas?
    I did reinstall and rebooted on a Win 11 machine.
    Which exact version of dBpoweramp do you have?
    • Altheia
      • 8
      I have 16.6 in the dB control. I cant find the version on dB Ripper directly. I assume it's 16.6.
      • Altheia
        • 8
        I just removed my version and installed the trial version. That works well! If I register it does not work! I originally purchased in 2017. Why is the trial version working and not the registered?
        • Altheia
          • 8
          The Trial version is 4/17/2025.
            See:
            • Altheia
              • 8
              Looks like I have to spend $34 to upgrade? Am I missing something?
                Correct
