Problem CD
  • MarkW
    • Feb 2015
    • 11
    Problem CD
    I have come across one CD so far that seems to be a problem. After 2 passes the Rip Status says "Re-rip" and proceeds to count down frames. It does this on every track on the CD. It then says "Inaccurate". The CD is not in AccurateRip, and this process takes a very long time.
    What exactly is the program doing, and is the end-result useful?
    Re: Problem CD
    It means that as the tracks are not in AccurateRip CD ripper will redo the pass, now if everything was good the 2 passes should match exactly, in your case they do not, all you know is there are ripping errors, which may or may not be recovered by 're-rip'. CD drives are not able to self detect errors 100% of the time, only AccurateRip can do that.
