Rip to flac - No sound
  • theoD
    • Mar 2025
    Hello,
    I've purchased DBPoweramp recently, running on a MB pro M1 with usb Superdrive, ripping cd did not produce any error, but all the flac file I've tested so far have no sound. I tried Quick time player as well as VLC and it is the same. The files open up, progress bar while listening but no sound output.
    Could you please provide any advice?
    Thanks!
    theoD
  • theoD
    • Mar 2025
    attached some debugs. The biggest file cannot be attached bc exceeds 100KB
    LastPCDone=99, EncoderError=0, evtShouldQuit=0
    Communicate [Get]
    ->-> [CloseDecoder]
    ->-> [CloseDecoder]
    <-<- [CloseDecoder]
    ->-> [EndConversion]
    <-<- [EndConversion]
    *** Information: Audio File Passed Verification
    File Size Check : 96297418 bytes Filename: /Users/tazsolo/Documents/cd rip/John Cale/Church of Anthrax/01 John Cale - Church of Anthrax.tmp
    File Size Check (before ID Tags Written): 96297418 bytes Filename: /Users/tazsolo/Documents/cd rip/John Cale/Church of Anthrax/01 John Cale - Church of Anthrax.tmp
    ->-> [IDTagWriter]
    Decodes [Get]
    Decodes [Get]
    Decodes [Get]
    Decodes [Get]
    Decodes [Get]
    Writing tags...
    IDTags [Set]
    ->-> [WriteIDTags]
    Opening file '/Users/tazsolo/Documents/cd rip/John Cale/Church of Anthrax/01 John Cale - Church of Anthrax.tmp' for write access: Opened
    ->-> [Open]
    Opening file '/Users/tazsolo/Documents/cd rip/John Cale/Church of Anthrax/01 John Cale - Church of Anthrax.tmp' for read access: Opened
    Init FLAC:
    Reading Meta Data:
    contained 0 tags:
    ->-> [ReadIDTags]
    <-<- [ReadIDTags]
    <-<- [Open]
    ->-> [Close]
    <-<- [Close]
    <-<- [WriteIDTags]
    ... writing tags succeeded
    <-<- [IDTagWriter]
    ->-> [Close]
    <-<- [Close]
    Communicate [Get]
    ->-> [AfterConversion]
    <-<- [AfterConversion]
    Conversion completed in 1 minute 1 second x8,7 realtime encoding
    File Size Check (core converter exit): 96297418 bytes Filename: /Users/tazsolo/Documents/cd rip/John Cale/Church of Anthrax/01 John Cale - Church of Anthrax.tmp
    • theoD
      • Mar 2025
      Found the issue, changing from 32 bits to 24 bits fixed the issue, if it can help others users
        To be honest you are best ripping at 16 bit, on playback the player often has upscaling mechanism (such as 8x over sampling), adding bitdepth on ripping does nothing for quality.
          And they are no longer bitperfect copies of the CD files. They are just larger for no reason.
          • theoD
            • Mar 2025
            Thank you for your input, will go for 16 bits ripping
