Offset values did not match across tracks
  • mrgou2
    • Dec 2024
    I want to reconfigure a drive I've been using on my previous computer and which I mounted on my new PC. However, when trying to configure it with a key disc, I get the following error (tried 3 discs already): "Offset values did not match across tracks: possibly this key disc has scratches, please try another disc".
    It means the drive is changing the offset per track, they should not do this, and makes the drive useless for audio ripping.
    All drives normally have a constant offset.
    • mrgou2
      • Dec 2024
      Must be a bug then. Eventually, I recovered the files from the AppData folder in my previous computer and moved them to the new computer where I re-installed the drive. Works like a charm.
