CD Ripping Speed remains at maximum
  • VincentH
    • Nov 2024
    Since today, my CD's are only ripped at maximum speed.
    I can also only select ‘maximum’.
    I also get the message: Windows Defender is restricting from accessing system.
    I have already added the exceptions (AccurateRip.dll, CDGrab.exe, CoreConverter.exe, MusicConverter.exe) in my AVG Antivirus.
    Even if I turn off my AVG Antivirus and reboot my computer again, i keep getting that message.
    ‘SCSI Pass Through (SPT)’ (CD Ripper options, CD ROM Communication) keeps changing to ‘Windows Internal’ after restarting CD Ripper.
    I use dBpoweramp Release 2024-11-04 [64-bit] and Windows 10 Pro 64-bit.
    Does anyone know how I can solve this problem?
    See:
    • VincentH
      • Nov 2024
      As mentioned earlier, I have already allowed ‘AccurateRip.dll, CDGrab.exe, CoreConverter.EXE and MusicConverter.exe’ in my AVG Antivirus = I have already seen that link. That doesn't help ;-)
        AVG Antivirus is not the correct area, it would be Defender.
        • VincentH
          • Nov 2024
          I don't see Control Folder Access
            On the image you post, at the bottom is Microsoft Defender Options, click it.
            • VincentH
              • Nov 2024
              Here is the screenshot of that.
              I already delete AVG Antivirus en reboot the computer = didn't help
                Search for Controlled Folder Access and switch it off.
                • VincentH
                  • Nov 2024
                  Controlled folder access is off.
                    Something is blockig dBpoweramp from access the drive directly, it is likely security software.
                    If you restart in safemode with networking option selected, then it will not load security software:
                    https://www.dell.com/support/kbdoc/e...-in-windows-10
                    • VincentH
                      • Nov 2024
                      On 11 november 2024, I ripped CDs without any problems.
                      From 13 november 2024, I had problems with the CD Ripper.
                      I went back to a restore point from 9 November, which made my CD Ripper work perfectly again.
                      Updated my AVG Antivirus and dBpoweramp to the latest version...Restarted my computer = CD Ripper still works perfectly.
