How much it takes to upload CD info to accuraterip?
  • Discogenes
    • Aug 2015
    • 16
    Hello,
    I try to rip this in order to get a certified log but it's taking longer than expected. Others CD's ripped in the meanwhile are already on accuraterip
    Jose
    Exact Audio Copy V1.1 from 23. June 2015
    EAC extraction logfile from 22. July 2015, 15:08
    Various / Chocolate Mix 1
    Used drive : PIONEER BD-RW BDR-S08 Adapter: 1 ID: 0
    Read mode : Secure
    Utilize accurate stream : Yes
    Defeat audio cache : Yes
    Make use of C2 pointers : No
    Read offset correction : 667
    Overread into Lead-In and Lead-Out : Yes
    Fill up missing offset samples with silence : Yes
    Delete leading and trailing silent blocks : No
    Null samples used in CRC calculations : Yes
    Used interface : Native Win32 interface for Win NT & 2000
    Gap handling : Appended to previous track
    Used output format : Internal WAV Routines
    Sample format : 44.100 Hz; 16 Bit; Stereo
    TOC of the extracted CD
    Track | Start | Length | Start sector | End sector
    1 | 0:00.33 | 8:51.62 | 33 | 39919
    2 | 8:52.20 | 4:53.50 | 39920 | 61944
    3 | 13:45.70 | 6:45.53 | 61945 | 92372
    4 | 20:31.48 | 5:20.35 | 92373 | 116407
    5 | 25:52.08 | 8:27.70 | 116408 | 154502
    6 | 34:20.03 | 3:58.30 | 154503 | 172382
    7 | 38:18.33 | 5:59.50 | 172383 | 199357
    8 | 44:18.08 | 7:13.12 | 199358 | 231844
    9 | 51:31.20 | 4:57.35 | 231845 | 254154
    10 | 56:28.55 | 4:36.60 | 254155 | 274914
    Track 1
    Filename D:\EAC rips\01. Various - Chocolate Mix 1 Megamix.wav
    Pre-gap length 0:00:02.33
    Peak level 97.7 %
    Extraction speed 5.0 X
    Track quality 99.9 %
    Test CRC 53C08EE3
    Copy CRC 53C08EE3
    Track not present in AccurateRip database
    Copy OK
    Track 2
    Filename D:\EAC rips\02. Zentral - Alarm (Original Version).wav
    Pre-gap length 0:00:02.00
    Peak level 97.7 %
    Extraction speed 5.7 X
    Track quality 100.0 %
    Test CRC 78F7F8B3
    Copy CRC 78F7F8B3
    Copy OK
    Track 3
    Filename D:\EAC rips\03. Sensity World - The World Won't Stop (Dance Version).wav
    Peak level 99.4 %
    Extraction speed 6.0 X
    Test CRC F43C624F
    Copy CRC F43C624F
    Copy OK
    Track 4
    Filename D:\EAC rips\04. Kike Boy - Jumper.wav
    Peak level 100.0 %
    Extraction speed 6.8 X
    Test CRC 519287D9
    Copy CRC 519287D9
    Copy OK
    Track 5
    Filename D:\EAC rips\05. Brainvibe - It's Hot (Wippenberg Mix).wav
    Peak level 96.5 %
    Extraction speed 7.1 X
    Test CRC F7F3E0E5
    Copy CRC F7F3E0E5
    Copy OK
    Track 6
    Filename D:\EAC rips\06. Alberta - Be Crazy (Radio Edit).wav
    Peak level 97.4 %
    Extraction speed 6.5 X
    Test CRC 6D6F9D8D
    Copy CRC 6D6F9D8D
    Copy OK
    Track 7
    Filename D:\EAC rips\07. Chaka Boom Bang - Tossin' And Turnin' (Ultimate Club Mix).wav
    Peak level 94.3 %
    Extraction speed 7.9 X
    Test CRC 316244BD
    Copy CRC 316244BD
    Copy OK
    Track 8
    Filename D:\EAC rips\08. No Mercy feat. Tony D. - Missing (I Miss You Like The Deserts Miss The Rain) (Manumission Trance Mix).wav
    Pre-gap length 0:00:01.65
    Peak level 95.5 %
    Extraction speed 8.4 X
    Test CRC B4292015
    Copy CRC B4292015
    Copy OK
    Track 9
    Filename D:\EAC rips\09. Don Cu - The Guitar Sound (Remix).wav
    Peak level 98.8 %
    Extraction speed 7.6 X
    Test CRC F138C751
    Copy CRC F138C751
    Copy OK
    Track 10
    Filename D:\EAC rips\10. B.P.M. System - C' Est Si Bon.wav
    Pre-gap length 0:00:01.47
    Peak level 98.3 %
    Extraction speed 9.2 X
    Test CRC 10BC639A
    Copy CRC 10BC639A
    Copy OK
    None of the tracks are present in the AccurateRip database
    No errors occurred
    End of status report
  • BrodyBoy
    • Sep 2011
    • 780
    Re: How much it takes to upload CD info to accuraterip?
    If you are asking how long it takes for new CD releases to appear in the AccurateRip databases, it varies a great deal. Popular albums usually show up very quickly, while obscure albums can seem to take forever. Most are something in between. Your post doesn't say what album you're talking about, but if you are getting a secure rip without errors, it doesn't really matter whether it's found in AccurateRip....you can be fairly assured that you have good copies. Your own rips will eventually be added to the databases.
    What do you mean when you say you're ripping "in order to get a certified log?" Accurate copies are typically the objective, and it sounds like you already have that.
      It takes about 1 month, but if it is your submission that you later re-rip and certify against, then that is not as good as verifying against someone elses rip.
      • Discogenes
        • Aug 2015
        • 16
        Accurately ripped (confidence X) [XXXXXXXX] (AR v2)
        All tracks accurately ripped... and those stuff
        First time I tried to rip this CD1 of 2CD set had a reading error due a scratch on track 01.
        Now I got a new copy but I found the last track ended with no silence, so I ripped it again with a drive that supports overreading in order to read it all.
        Since this, this CD entry seems to have been deleted from the Accuraterip database, while the CD2 remains on it.
        It's a valuable CD and it requires to be as trustfully as possible
        • Discogenes
          • Aug 2015
          • 16
          Does it has the overreading option something to do with the required rips? My drive can overread and I use it because last track is not 100% silent at end
            Overreading is not required.
            • Discogenes
              • Aug 2015
              • 16
              It's enough trying to rip it again in a different computer? Or also I have to rip it in other place/IP?
                A different CD drive helps, but you are comparing your own disc to your own disc, AccurateRip works so well because you compare your rip to someone elses disc.
                • Discogenes
                  • Aug 2015
                  • 16
                  I'm afraid that last track will always give a different CRC since it doesn't end in null samples, so depending the drive offset there will be more or less null samples at end.
                  PIONEER BD-RW BDR-S08 is the only drive I have it can read the end properly without padding with zeroes.
                  Will another PIONEER BD-RW BDR-S08 help? Same model but different serial?
                  I also have a pair of +6 offset drives (each one from different vendor) and also another pair or +667 offset drives (also each one from different vendor)
                  I can rip it in both +6 drives, but I wonder if this will prevent to get the "Accurately ripped (confidence X) [XXXXXXXX] (AR v2)" message in all tracks.
                  It's so ugly to find some tracks verified and others don't.
                    Drive offsets do not affect AcurateRip and ripping the last track, it is designed to have a constant AccurateRip CRC.
