Rerip problems
  • Buns
    • Apr 2014
    Rerip problems
    This is probably a matter of incorrect settings, but when I try to rip a CD dBPoweramp Grab wants to re-rip every single track. Furthermore, this happens with every single CD I try to rip. In every instance the number of frames to be re-ripped is in excess of 3,000!! Has anyone encountered this problem and solved it?
    Re: Rerip problems
    Try to disable C2 pointers.
    • Buns
      • Apr 2014
      Re: Rerip problems
      Thanks very much. That solved the problem.
