How do I access "Reference required" features of dBpoweramp
  • Randy0223
    • Jun 2015
    I installed the trial version of dBpoweramp to my Windows 7 computer. Product looked good so I purchased and installed the "Reference 15.3" version. I need to access a "Reference required" feature (specifically secure ripping) but the option doesn't seem to be available.
    If it's any relevance, I uninstalled the trial version before downloading and installing the Reference 15.3 version.
    Any help on this is greatly appreciated.
    Randy0223
    Re: How do I access "Reference required" features of dBpoweramp
    I suspect maybe it is not installed properly. Find the dbpa "configure" exe icon (or file in the dbpa or illustrate subdirectory). Run this. It should show the version of dbpa you have and should say "Registered Reference, Release 15.3" Does it?
