Can't rip CD's using slim external optical drive
  • RodW
    • Oct 2013
    My PC has a conventional internal slim optical drive with which I'm able to rip CD's to FLAC successfully using DbPoweramp. However, when I use a slim external USB 2.0 optical drive, the process takes only a fraction of the time and the FLAC files produced will not play. It should noted that the slim external optical drive operates normally in every other way, playing CD's, burning to DVD's etc.
    Re: Can't rip CD's using slim external optical drive
    Try the latest R15.3 beta, you can find in the testing section of this forum.
    • RodW
      • Oct 2013
      Thank you Spoon
      I did what you said and the problem has been solved. May I say that the solution was well explained and easy to implement.
