Codec "Calculate Audio CRC" issue
  • ampxyz
    • 22
    Hello.
    In "rip to" choose "Calculate Audio CRC"; in encoder settings check: AccurateRip crc... and MD5..., i do the process and the ripper returns the md5 of each file, thats ok, but doesn't the accuraterip crc code. I'm using originals cd's (did this with 3). Somebody know something about this?
    • 46167
    Re: Codec "Calculate Audio CRC" issue
    You would never rip to the Calculate Audio CRC utility codec, as it does not write any audio tracks. It is designed to be run later on, with existing files.
    • ampxyz
      • 22
      Ok.
