Pioneer BDR-208DBK Ripping Questions?
  • martinmeasic
    Hello everyone,
    Before I start to rip my cds using dbpoweramp cd ripper, I want to configure my settings properly. Now I'm not sure if this goes in this thread/forum or not and if it doesn't please tell me where to put it. I also only want answers if you know you're right as I don't want to re-rip all my cds again. Ok so, does anyone know if this drive supports:
    C2 Error Pointers? If no I won't enable it and if yes should I enable it? I read online somewhere that it does support it but when I right click the "[ Technical ]" window it says "C2 Error Pointers: No" so I'm not quite sure what to believe.
    Read into lead-in lead-out? If no I won't enable it and if yes should I enable it?
    Also is there anything else that I should be aware of in the settings options? I don't care how long it takes as long as I only have to do it once.
    Also (again, I know) I have a TSSTCorp SH-222BB Would that maybe be better at ripping cds?
    Martin
    Last edited by martinmeasic; April 19, 2015, 10:59 AM. Reason: Added another detail.
    • 1752
    Re: Pioneer BDR-208DBK Ripping Questions?
    Hey Martin,
    as long as you get accurate rips it doesn't matter at all, how your drive is configured. An accurate rip is an accurate rip - you can't improve it's quality by re-ripping, because you already have a 1:1 copy.
    It's good to have more than drive, not from the dBpa point of view, but if you have a scratched disc. Different drives have different capabilities to handle those problematic discs. But in the end: if you have an accurate rip, it doesn't matter which drive has ripped this file.
    • thexfile
      • Jul 2010
      • 177
      I have a BDR-209EBK/UBK and dBp doesn't recognize most Pioneer drives firmware. Stick with the Samsung.
      • martinmeasic
        Hmm, thankyou for your reply! I ripped one cd using the Pioneer BDR-208DBK and it registered with accurate but one of the tracks displayed something like "Accurate or differs in samples __, __, __, __." Does this mean it's still ok?
        • martinmeasic
          Thank you for your reply too! What exactly do you mean? Does it mean it could be saying it has a feature but really doesn't or vice versa?
            • 44047
            You would have to post the message exactly as it appears.
            • martinmeasic
              Oh how silly of me thanks for saying that. I feel pretty dumb now..
              • martinmeasic
                Originally posted by Dat Ei
                Hey Martin,
                • martinmeasic
                  • thexfile
                    • Jul 2010
                    • 177
                    Only Max speed is recognized with Pioneer drives. Your Samsung should list all it's different speeds.
                    • martinmeasic
                      But that shouldn't really interfere. I mean the speed wouldn't matter or would it?
                        • 1752
                        Not really. In case of a scratched CD with read errors the drive should turn down the speed by itself.
