Can't edit id tags on right click menu
  • tuneup
    • Feb 2015
    • 44
    The default setting in dBpoweramp config is to Edit ID Tags on Right Click Menu, but as you can see from screen shot at http://postimg.org/image/slttqyorx/4df55643/ this doesn't work. This is V. 15.2 and the problem was the same in 15.1. Any suggestions other than installing a separate ID tag editor?
    Re: Can't edit id tags on right click menu
    You are right clicking on a folder, the option only appears if right click on audio tracks in the folder.
