artwork problem...
  • daleyb
    • Oct 2014
    • 235
    artwork problem...
    Just ripped to cds (by same artist) Orig.cd. No Artwork came up for either.After ripping i went into perfect Tunes to try to add /fix artwork.However, the 2 cds did not appear.?
    Any Ideas.I think You can get artwork from Google images/amazon stock-but i cant do that because its not showing its not there in perfect tunes.
    I appreciate its easy for folk to come up with ideas to improve DBPA-which to be fair- may be hard to implement /configure on it in reality.But it would be nice to find artwork at ripping stage-then its done!
    Re: artwork problem...
    If you click the single 'Fix' button in PerfectTUNES, then the whole internet is searched.
    • daleyb
      • Oct 2014
      • 235
      Thanks Spoon-but ican not do this because it not showing the 2 cds up in that section after P.TUNES has searched.. i would fix if the 2 cds came up-but their not there. I know the artworks not there because they did not show up after at ripping stage.
      Tried wm p. and the artwork came up there.
      The plot thickens...?
        Make sure these files have an album name.
        • daleyb
          • Oct 2014
          • 235
          Yep done that -still not there.The cd accurate (2) so must be in library.Is there any way of finding artwork cover and putting in file folder in windows with tracks../ I think that be a no-it wont be embeded together-i think....
          Still not the end of world it only 2 cds so far!
