Hello and Problem (CD Detection)
  • KathyK
    • Feb 2015
    Hi everybody,
    can somebody help me ?
    i have purchased the CD Ripper and it is not detecting any CD drive.
    Windows (7 64bit) is seeing it and can play music from it.
    I tried to search but appears none have this problem :-(
    Thank you in advance...
    Kathy
    Re: Hello and Problem (CD Detection)
    Close CD Ripper, open Configure dBpoweramp >> Music Converter
    enable the 'Debug' option (end of the option list), close the Configure program, start CD Ripper, load a disc into your drive, wait 2 minutes, then close CD Ripper, a debug log will show in notepad, copy and paste the contents here please.
    • KathyK
      • Feb 2015
      thank you,
      it was screaming all over the place
      i disabled the UAC and now it works...
      Any idea how to force Batch Ripper to autostart in Batch mode? So if i have it in autostart folder that i dont need to press the batch button that it would start working?
      Or at least a hot key button for the ripping ?
        You can start it with command line option --autorip
        note this only works for manual load and eject.
