AIFF rip sounds very thin - almost bass..less
  • len bell
    • Jul 2013
    • 22
    I ripped a few AIFF files and they sound very very treble-y, almost no bass. I dont have this issue when i rip FLAC. what could be cause this?
    Re: AIFF rip sounds very thin - almost bass..less
    Visit:
    Install 'Calculate Audio CRC' and convert the same AIFF and FLAC file both to this encoder, it simply shows a CRC for the audio, if the CRC is identical then the audio contained in the files are identical, and it will point to your player.
    • len bell
      • Jul 2013
      • 22
      ok i follow step one, but how do i convert the files to this particular encoder.
        Right click on FLAC File >> Convert To >> select encoder as '[Calculate Audio CRC]' >> Convert
