Secure Rip Wont Work Please Help
  • BCRip
    • Dec 2014
    Just installed CD Ripper and set it up according to the setup guide for secure ripping with the exception of ripping to aiff instead of flac. The first CD ripped properly with the number of passes configured in settings and resulted in a secure rip checkmark for each track. Every other CD rips with only one pass per track and no secure ripping. When I check options the secure rip box with all of my correct settings is checked. Any ideas why CD Ripper is only performing one pass per track.
    • 6189
    Re: Secure Rip Wont Work Please Help
    do these perhaps have ACCURATERIP matches. If something matches AR database info, then it is even better than secure rip and no need for multiple passes.
    • BCRip
      • Dec 2014
      I think they did have matches. Didn't realize only one pass needed. That's awesome, thx.
        • 6189
        That's the beauty of dbpa and accuraterip. be sure to turn on the full logging in dbpa ripper then a txt file with ripping log is saved in the album subdirectory (and you can always see this sort of info after the fact)
        • BCRip
          • Dec 2014
          I haven't ripped in awhile. accuraterip is just amazing, sooooo much faster. Thx for the logging tip.
