CD Drive Offset
  • RaymondYu
    • Nov 2014
    CD Drive Offset
    I recently upgraded my PC and moved up to the latest versions of the dBPoweramp software - both the ripper and PerfectTunes. After the upgrade, I saw the message: "AccurateRip is unconfigured (waiting for key disc to find offset). I am still using the same Blu-ray writer to rip my CDs. I remember the offset was automatically identified the first time I used this drive with the previous versions of this software.
    How do I configure my drive with AccurateRip with this current (latest) version of the software?
    Thanks and best regards,
    Raymond.
    • 46198
    Re: CD Drive Offset
    You have to keep feeding it discs until it configures.
    • RaymondYu
      • Nov 2014
      Re: CD Drive Offset
      Just any CDs?
      Thanks for the prompt reply!
        • 46198
        Re: CD Drive Offset
        Yes eventually it will configure. There is no need to rip the cds, just have track listing.
        • RaymondYu
          • Nov 2014
          Re: CD Drive Offset
          Got it. Problem solved. I noticed that you have to put in a CD which is already in the AccurateRip database.
          Thanks again!
