What happened to ripping an Audio CD as an option when inserting an audio CD?
  • probedb
    • Sep 2006
    • 32
    Since installing 15.1 the option is gone. I used to stick in an audio CD and it'd ask if I wanted it ripping with dbPoweramp as one of the options.
    Now it's gone, not even in the list any more?
    Bug?
    • 46198
    Re: What happened to ripping an Audio CD as an option when inserting an audio CD?
    Try uninstall, reboot Windows, then reinstall. The option is simply a registry entry. You had r15 previously?
    • probedb
      • Sep 2006
      • 32
      I was on 14.something previously. I'll try the reinstall.
