Low Rez Display in R15 x64
  • john0808
    • Apr 2013
    When I upgraded from R14, dBPoweramp installed the 64-bit version, as I'm running Windows 8.1x64. It displays in low rez, looks awful, and is inconvenient to use with large windows that flow off the screen. The old 32-bit versions always displayed properly, and I'm going to keep using R14 until dBPoweramp fixes the x64 display.
    • 46198
    Re: Low Rez Display in R15 x64
    Can you post a screenshot? Upload to postimage.org and post a link.
    • john0808
      • Apr 2013
      Solved: I checked "Disable Display Scaling on high DPI Settings" under Compatibility tab on Properties of the shortcut.
