Problem using dbpoweramp when destination is a network drive
  • steveg
    After using CDex for many years, I'm trying out dbpoweramp.
    Works fine apart from one thing. My file destination is a netwrok drive - e.g. \\server1\music\flac
    This works fine for the first CD I rip. With the next CD, it says it can't write the destination file. If I close and reopen dbpoweramp or even if I use windows explorer to just go to the destination drive, then it will work again.
    Any idea what's going on??
    (Note that there is NO problem with access to the network drive. It is in use all the time.)
    Re: Problem using dbpoweramp when destination is a network drive
    A network drive should be transparent to dbpoweramp, ie it should be the same as writing to a local drive. If dbpoweramp says it cannot access, then it is the network server which is refusing, not sure why, perhaps security software on your PC?
    • steveg
      Yes - that's what I would assume. But the network drive is serving up email, music and backup services all the time - and CDex has been saving to it happily for years.
      I'll do some more experiments tomorrow and report back - it's bound to be something I'm doing wrong!
      Steve
      • steveg
        This is all very weird.
        If I open Windows Explorer and look at the destination file first, then dbPoweramp works. Otherwise, it says it can't write.
        Every other program on the client can read and write to that folder completely consistently - indeed to anywhere else on that server share. Not surprising as the permissions are 'Full control' for 'Everyone'!
        Configured cdex to write to the same folder on the server it it works every time!
        I've been at IT professional for 20 years and I've never come across as inconsistent a problem as this one!
        Steve
          Try right click on CD Ripper >> Run as Administrator.
          • steveg
            Latest discovery is that it appears to work fine IF I map the shared drive!
            i.e.
            a save path of \\Server1\mp3\flac displays the problem I'm talking about
            a save path of Z:\flac works perfectly where Z: is mapped to \\Server1\mp3
            I really can't explain that one!!
            Steve
