Correction Offset Missmatch
  • accuratecopy
    • Jun 2014
    • 15
    Hi there!
    I try to get Accuraterip working on my second drive, model ASUS SBC-06D2X-U.
    But everytime i put a key disc in the drive, i got a window with this message "AccurateRip will not key to this offset as it miss-matches the drive database offset. [ Calculated offset value + 103 samples, + 412 bytes. ]
    I checked the database and it seems like the correction offset for this drive is +48.
    What is the procedure to follow to run Accuraterip on this drive?
    Thanks in advance.
    • 46198
    Re: Correction Offset Missmatch
    How many discs have shown that offset? and are the discs not part of a single box set (or compilation).
    • accuratecopy
      • Jun 2014
      • 15
      I retried with 3 different discs (Adema - Adema; Adema - Insomniac's Dream EP; 311 - From Chaos), but i have tested many more key discs and the calculated offset value is always +103 samples, +412 bytes. Tried Faith no More - Who Cares a Lot as i'm writing this message and got again +103 samples, +412 bytes.
      • accuratecopy
        • Jun 2014
        • 15
        Can you try to add this drive or maybe change the offset in the database?
        How drives if the same reference can give different offsets?
          • 46198
          The next monthly update, we will purge this drive from the database, so that it will key using 3 discs.
          All drives are supposed to have a consistent offset, and they do, there is a handful of drives which seem to change over time.
          • accuratecopy
            • Jun 2014
            • 15
            When is the next monthly update?
            I will try it again after the purge.
            Thanks a lot
              • 46198
              Beginning of the month, then it might take 1 week for the drive settings to get to your computer.
              • accuratecopy
                • Jun 2014
                • 15
                Is it possible to see the status of the purge for the ASUS SBC-06D2X-U?
                  • 46198
                  Sadly the removal had an error, I have corrected this error however the regeneration of the database is 4 weeks away.
