Help with ID tag/ manipulation/ smart capitalization
  • swhiteindiana
    • Dec 2003
    I can't be imagining things...:cry: I thought I saw this actually miraculously change all my titles from all CAPS to upper/lower case! It was really cool and now I can't seem to repeat the feat!!
    What's the trick to get this to process your Title entries? What did I (accidentally) do to get it to work? This program was saving me lots of trouble until I saw this work... now I want to use this and I can't remember what I did! Please help!
    Re: Help with ID tag/ manipulation/ smart capitalization
    You would set the Encoder as '[ID Tag Update]' and set the options there.
    ID Tag update is found in Codec Central above.
    • BrodyBoy
      • Sep 2011
      • 780
      There's also a smart capitalization option on the metadata details page.....unless you need/want to set some specific rules, that option will take care of most of it without having to use the DSP.
      • swhiteindiana
        • Dec 2003
        Thanks for your help.
        My CD's don't have any title data on them. I retrieve this data from the internet. I am certain that I did something to change the retrieved data to upper and lower case before I could rip it to wave files, but I can't seem to find what I did. I set the encoder ID tag update to "Smart Capitalization," but nothing happens. I thought that was it, but it doesn't change the internet retrieved titles even after the rip. I can live with all caps, but would prefer without.
        • swhiteindiana
          • Dec 2003
          Ah, never mind!! I found out what I was doing wrong. I needed to reconnect to the online then go to the "Perfect Meta Data review matches" where there is a choice to make the Smart Cap processor work. Finally made it work. A little difficult to remember if you stumble on to it. There's no reference to it in the docs... at least I didn't see it.
