Installing and using WMA in CD Ripper
  • Craigd
    • Apr 2014
    Hello,
    I have installed the WMA codec from the dBpoweramp website, but unfortunately I can not set the CD Ripper to rip to WMA format.
    I have tried many things including searching for answers in help and on the web site.
    I am using Windows 7 64 bit.
    Craig
    • 46167
    Re: Installing and using WMA in CD Ripper
    It is not listed under the Encoder box?
    Which dBpoweramp do you have installed? r15?
    • Craigd
      • Apr 2014
      Hi Spoon,
      I am using R15. There was no WMA option in the Encoder box. I installed the codec a number of times, but I solved the problem by installing the codec into Program Files (x64). I will say that this is from memory. Life is busy.
      Thanks for the help.
      Cheers,
      Craig
