Problem configuring AccurateRip on Pioneer BDR-XU03
  • mickeysoft
    • Mar 2014
    Just got this drive today, and when I fire up dBpoweramp, it presents the "Configure AccurateRip" dialog box.
    The dialog says:
    CD Drive Type: PIONEER - BD-RW BDR-XU03
    Expected Offset: Unknown Drive
    I then hit the "Configure" button.
    After a little while another dialog comes up saying:
    "This Key Disc cannot be used for offset detection it does not match the AccurateRip stored disc, or your drive does not exist in AccurateRip and this disc has multiple pressings stored. Please try a different Key Disc."
    I've tried a few discs, all with the same result.
    Any ideas? Any additional info I can provide?
    Re: Problem configuring AccurateRip on Pioneer BDR-XU03
    Because the drive is not in our database you need 3 discs which give matching offsets, and the discs cannot have multiple pressings in our database (so try more modern discs).
    Keep feeding discs and it will configure eventually.
    • mickeysoft
      • Mar 2014
      Alright! Thanks so much, that worked. It took about 20 discs, I guess a lot of discs have multiple pressings. Anyways, glad it's working! :-D
