Error for every track and every CD I try to rip
  • Paul Hammond
    • Jan 2014
    I installed dBpoweramp today and have tried to configure it according to the advice in the set-up guides. The problem is that I'm getting an error for every track (and every CD) that I try to rip. In the "Rip Status" column, it shows "AR" and "Insecure" against each track. And the error log shows the following:
    Information ripping to [Multi Encoder], 'Track 3' to 'C:\Users\Angela&Paul\Music\St. John's College Choir, Cambridge\Hear My Words; Choral Classics from St. John's\03 St John's College Choir, Cambridge - Pärt; Bogoróditse Djévo.IGNORE'
    ** Aborted: Have to ReRip 2669 Frames, Re-Rip Limit Set to 100 Frames
    Track 3: Ripped LBA 78481 to 84281 (1:17) in 0:30. Filename: C:\Users\Angela&Paul\Music\St. John's College Choir, Cambridge\Hear My Words; Choral Classics from St. John's\03 St John's College Choir, Cambridge - Pärt; Bogoróditse Djévo.IGNORE
    Insecure [Pass 1, Ultra 1 to 2, Re-Rip 2669 Frames]
    All of these CD's that I'm trying to rip are in the AccurateRip database. My Secure Ripper settings are as follows:
    Minimum Ultra Passes: 2
    Maximum Ultra Passes: 6
    End After Clean Passes: 2
    Maximum Re-Reads: 50
    Set Drive Speed: Maximum
    Drive Read Cache: 1024KB
    Clear Read Cache with FUA = unchecked
    C2 Error Pointers for Error Detection = checked
    8Kb Transfers = unchecked
    Secure Rip Abort - After Unrecoverable Frames = 1 frame
    Secure Rip Abort - When Have to Re-Rip = 100 frames
    Secure Rip Abort - After Ripping a Track For = 10 minutes
    Interpolate Unrecoverable Frames = unchecked
    Mark Track as Error if Insecure = checked
    Cancel Disc Ripping After Any Insecure Track = unchecked
    Please can anyone help?
    UPDATE: TURNING OFF C2 ERROR INFO SEEMED TO DO THE TRICK
    Re: Error for every track and every CD I try to rip
    Yes your drive is not supporting C2 correctly, is should be disabled.
