Need Help Accuraterip Cleaning
  • Drakoliona
    • Jan 2014
    Hi, here I installed Exact Audio Copy on my PC, and uninstalled, but with time I decided to reinstall parcontre I have not got the message to configure the drive (drive offset) so I would like to know how clean everything, registry and files, to properly reinstall Exact Audio Copy
    thank you
  • dbfan
    • Jan 2011
    • 937
    Re: Need Help Accuraterip Cleaning
    If you do not get the configure message then it probably is already configured, rip a cd and see if accurate rip verifies the rip.
    • Drakoliona
      • Jan 2014
      How i knew if accuraterip verifies the rip ?
      So, i'm go in Appdata/Roaming and delete AccurateRip, and in regedit :
      HKEY_CURRENT_USER\Software and delete AWSoftWare Folder, and Illustrate Folder, and reinstall EAC, it's good ?
        AWSoftware not nothing to do with AccurateRip, however the other locations are correct.
        • Drakoliona
          • Jan 2014
          I need only clean this? or other files in registry ? and files ? for proper reinstallation
            Just the ones listed
            • Drakoliona
              • Jan 2014
              Last question and I'll leave you alone ^ ^ I need to uncheck GD3 and check CTDB plugin, but I can not remember if I did well, how I can be on without re install the program?
                This is a question about EAC, it would be best on their support forum.
