Accuracy Numbers
  • dwatts9501
    • Nov 2013
    Accuracy Numbers
    I am new to using the ripping software. When I run the CD rip I get accuracy numbers from 2- 16.
    I assume the higher the number the better, what is considered good and how high does the accuracy number go?
    • 5911
    Re: Accuracy Numbers
    there is a max, but I forget what it is. But higher is not really "better". These are not "quality" ratings. They simply report matches in the accuraterip database. For example, if you get "accuraterip (2)" it means that two other people that ripped the same title CD got exactly the same CRCs from the rip. So this means that two others, with different physical copies of the disk, using different computers, and different drives, got the same data, bit for bit, as you got in your rip. So even accuraterip (1) is impressive (and much better than you ripping twice and getting the same CRCs, as you could have a consistent error in your drive, on your copy, etc.). (note that if you get AR (1) from reripping your disk weeks or months later on, you may be matching back to yourself in the AR database so that's not as good of course).
    very popular disks may have many matches. More obscure disks may have fewer. Newer, and less popular disks may not even be in the database (yet).
    • dwatts9501
      • Nov 2013
      Thanks, that helps!
