Copy settings and metadata cache to fresh installation
  • VirusKiller
    • Aug 2008
    • 9
    I'm probably going to re-install the OS on the PC which currently has dBpa installed.
    Is there a way for me to copy the ripper metadata cache and all other settings to a new install?
    Re: Copy settings and metadata cache to fresh installation
    in the registry:
    HKEY_CURRENT_USER\Software\Illustrate
    and this path:
    %appdata%\dbpoweramp
      in the registry:
      and this path:
      Can we have a sticky (possibly under FAQs) listing all Illustrate software settings registry and file path locations?
        Added
        • VirusKiller
          • Aug 2008
          • 9
          Sorry to be awkward, but can I copy the cache from a Windows 7 machine to an XP machine? I tried copying it to C:\Documents and Settings\Administrator\Application Data\dBpoweramp but it won't pick up the cached metadata and artwork.
          Do I need to copy any registry entries as well? (I can't do a direct import as the machine is different with a different drive etc. It's a VM actually.)
            It is based on user name, so you would have to make sure you copy to the right location, on Windows 7 by default the administrator account is not used.
            • VirusKiller
              • Aug 2008
              • 9
