Window display issue: program window keep resizing to 1/4 screen
  • FrankP
    • May 2012
    • 10
    For several days, my dBpoweramp has been having issues displaying on my screen. The program insists on being anchored to one corner of the screen or another, and I cannot move it where I want it. And I resize it to a size that is convenient, then it jumps back to 1/4 of the screen. I reinstalled but no improvement.
    • 46198
    Re: Window display issue: program window keep resizing to 1/4 screen
    CD Ripper?
    • FrankP
      • May 2012
      • 10
      Yep
        • 46198
        As a test, change the encoder in CD Ripper, then close CD Ripper, and restart CD Ripper. Does the change stick between starts?
        • FrankP
          • May 2012
          • 10
          Yes, changed from FLAC to WAV, closed and reopened and it was WAV; reset to FLAC, reclosed and rereopened and now it is FLAC
            • 46198
            What happens if you maximize it, close it and reopen, it is maximized?
            • FrankP
              • May 2012
              • 10
              Yes, it reopens maximized. If I then de-maximize, it is 1/4 of total screen size, centred in the screen; if I try to reposition it, it again pops into one corner or another. It also tends to re-size to 1/4 screen when I get metadata online - when it refreshes, it pops to 1/4 size.
                • 46198
                So when you drag the window it is jumping into corners? it is Windows which decides to do this (or a window help if you have such installed).
                • FrankP
                  • May 2012
                  • 10
                  I'm not sure who's deciding but it's not me... yes, if I try to drag the window it resizes to 1/4 frame anchored to a corner. Any other programs I can resize, drag, etc. without this behavior.
                    • 46198
                    We have no such 'clever' code in our programs, the resizing is controlled by windows.
                    • mdubin
                      • Jul 2013
                      • 42
                      This might help:
                      mdubin
                      • FrankP
                        • May 2012
                        • 10
                        In fact, it started happening with Office programs as well... but not IE 10, which continued to work normally. I uninstalled my Samsung Multiscreen program and it seems that may have fixed the problem. Although why it began misbehaving, after years with no problems, will remain one of life's mysteries.
