Problem with DSP
  • madmike
    • Aug 2013
    Problem with DSP
    I seem to have a problem with the DSP "Move destination file on Error" in CD Ripper.
    I have set it up like this:
    The idea is to just rename the problematic file to <filename>-ERROR in its original folder.
    I am getting a <filename>-ERROR file, but the the original file is NOT deleted.
    Could this be a bug?
    /Mike
    • 46198
    Re: Problem with DSP
    Possibly yes, we will mark as a possible bug.
      • 46198
      The issue here I am sure is that you have 2 things which perform an action after conversion, the ReplayGain and move on error. If checking for corruption use the move on error in one pass (conversion), and then use the ReplayGain utility codec to apply replaygain.
