help please-error only works for flac total_samples count in streaminfo
  • LanceL
    • Aug 2013
    this is the error I get when I try to play flac files ripped in db poweramp in a cmp/cplay machine with appropriate cue files.....can anyone offer assistance as to what this means and how to resolve?
    Thanks in advance
    • 46198
    Re: help please-error only works for flac total_samples count in streaminfo
    What is the exact error message please?
    • LanceL
      • Aug 2013
      Initially I get :
      cplay 2.0b39 sse2
      cue,wav, or flac file could not be processed
      Details at the bottom of the diagnostics display
      clicking on diagnostics...and the end of many things loading successfully as the album -flac files begins it states on last line....
      Error:only works for flac total_samples count in streaminfo
      I also can see that as the first flac file trying to be loaded for samples it has on the last line before the error message
      Samples:10000 (-35791394:-8)
      Is it something I have setup wrong in the flac encoder (Although) it is all at default settings
      Thx
      Lance
        • 46198
        What generated the cue file? the error points to the cue file not the flac file.
        • LanceL
          • Aug 2013
          Recursive cue creator
          There is not much to select in this program and I have used it before successfully...can you give any suggestions as to what to look at/for
          Thx again
            • 46198
            Try playing the flac file (without cue sheet in cplay) if it can play then the problem lies with cue creator.
            • LanceL
              • Aug 2013
              The cue files look identical to the ones that are playing
              however, when I look out a ripped track on my win 7 desktop by just holding the mouse over it or right click properties I see there is no length in the file nor genre...the dynamic file folder structure is:
              [IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][]\[album]\[track] [artist] - [title][length_mmss][genre][year]
              I 'm sure I'm doing something wrong in db power amp.... can you help....I am thinking that maybe the missing length is what the error message is referring to as as total samples count?
                • 46198
                Email one of your flac files please:
                  • 46198
                  Which version of dBpoweramp did you rip this flac file with?
                  Also do you know why there are no ID tags in the file except AccurateRip tags.
                  • LanceL
                    • Aug 2013
                    Db music convertor release 14.2
                    Flac release 14 (1.2.1)
                    Have no idea as to why no id tags.....pretty much ripped as installed /default stings besides for choosing flac, 16 bit, 44.1khz and folder to dump into
                    I did try to add on the time and genre parameters under the naming parameters to see if that made any difference and it still did not include times in the files
                    Thanks so much for looking at this
                    • LanceL
                      • Aug 2013
                      With your comments on which version I upgraded to latest version and that seemed to solve it...everything working well....thanks so much for your time and help
                        • 46198
                        Odd because it said FLAC encoder 1.3.0 and only R15 beta has this encoder.
